Pulling Driver's Side Turbo
Removing the engine mount makes the task much easier
Good morning,
Do you think we have enough space to remove identified wastegate bolts and loose flange that hold CHRA cartridge en manifold section together? If yes, i will only replace the worn intake/turbine and keep manifold bolted on engine.
