StingerT303
I am trying to remove the front struts to install my lowering springs (rears already done, rear sway done).
The strut doesn't have two bolts at the bottom to undo like most other cars I have worked on. Instead, the bottom of the strut slides down a sleeve into place and must be lifted out to be removed. The height of the strut prevents it from being lifted high enough to be removed that way. Also, the shape of the wheel well doesn't allow the strut to be tilted out and removed that way.
I am at a complete loss. Whatever amount of money I saved by doing this myself wasn't worth it, and I have done plenty of wrenching and have all the tools I could need.
If you know how to deal with this, please reply, or better yet, call me. 303-912-8187. I'll be in the garage banging my head against the wall.
Please hold back all the "Thats why I dont do suspension work at home" comments... This is like one of those impossible puzzles with the two nails bent around each other.
