Mr. Alsadah
- Nov 8, 2023
I have a 2019 Kia Stinger GT2 V6. I noticed the passenger door doesn't have a center lock switch from the factory. So, I bought the window switch that has the lock button and tried to remove the passenger door panel to check the wiring connection by comparing it to the circuit diagram in the manual, I found that the passenger window switch connector has 6 wires. I connected it to the new window switch (with the center lock button) and everything works (the window goes up/down, and illuminates) except the center lock button. I am not sure if there is a relay or fuse that needs to be installed or if I have to wire it to another connector. Any suggestion will be helpful.
Old switch
Wire connection
After installation
Wiring pins and diagram
Old switch
Wire connection
After installation
