Jordan clarke
- Jun 16, 2018
Hey guys,
I own a 2012 gen sedan 5.0lrspec. Trying to get a lsd in it but the only LSD I can find with a exact ratio and most likely is built bigger (Genesis Coupe diff is smaller) to handle the extra hp is the stinger diff.
We've cross referenced the diff to be a direct swap for 2015+ gen sedans but not for my generation. I'm basically curious as to what changed. Ring gears and pinion gears can be made custom need be.
So if you don't mind helping me out, if any of you have a lsd stinger diff that our can do measurements sometime I would appreciate it.
I can't post a link so if you can search quaife diff measurements under images there is a few pics of the measurements needed
If you could also get me a ring gear diameter and width then I could see whether or not I would need to make it custom.
Thanks for your help
