3.3TT Map 6 log
Daniel Langer
Map 6 with 13 psi boost over stock with Aral ultimate 102 octane fuel.
The log looks fine to me but i'm not an expert in reading logs.
Can someone please take a look at it?
I'm not an expert either but your ignition looks good, AFR looks good and you're making a ton of boost.. meaning your target is being matched by your actual goal. The only thing I question is your trims, they seem to be a bit high and don't drop. Normally they will jump to the 40-50 range and slowly taper into the 20's. Yours is in the 60's and do not drop?? Maybe because it was only a 2-3 gear pull? The other thing I can't explain that isn't normal is the way the app logged your WGDC. From 50 to 0 under full throttle and back to 50 doesn't seem right to me. There should be some actual activity there and for some reason it didn't log or store it.
Seems OK to me
