Map 2 boost level
TALONTRAX
Southampton, PA
Was driving on map 2 while watching data display (not log). The boost @ wot barely hit 15 psi. I did a quick search but couldn`t find what the stock or map1,2 etc. expected boost should be. This is the 1st time i watched the boost in this car (19 3.3 GT1 awd). In my 2.0 stinger the boost on map 2 (same JB4 unit) hit 22 psi @ wot consistantly. So any1 know if 20-22 psi is normal map 2 ? & why im only showing barely 15 now . . .
Sounds normal. Boost varies on a lot of factors. If you need tuning help just post a log.
2.0 and 3.3 have different stock boost.
15 psi seems pretty normal on a 3.3 with map2.
It is actually even a nice number, I would say,
but as Terry said it depends on many factors.
