Maintec evc exhaust install help!
Discussion in 'Engine, Drivetrain, and Exhaust Discussion' started by StingerNYC, Sep 5, 2018.
  1. StingerNYC
    StingerNYC United States Active Member
    292
    167
    Queens, NYC
    I received from Korea this exhaust system today. Everything seems to be of top notch quality but it did not come with any instructions or diagrams for the install. I am waiting on a response from Korea for some instructions, but doubt I will get anything in English.
    It came with a small wireless module and remote. Simple enough, 1 12v wire and a ground. My concerns are on the hose connections. There is a small motor(?) with a blue hose and cap already installed and then two other nozzles for hose hookup. If I blow in one the air goes right out the other. It also came with a couple T adapters for the hoses. The Mufflers have an actuator with a hose nozzle.
    Anyone have experience here that can give some advice on the install? Is this similar to the junbl evc? If it is does anyone have the install instructions I could see?
    See the photos below. Thanks.
    IMG_20180905_182925.jpg IMG_20180905_183024.jpg IMG_20180905_183009.jpg IMG_20180905_183003.jpg IMG_20180905_183432.jpg IMG_20180905_185200.jpg IMG_20180905_184902.jpg IMG_20180905_185239.jpg
  2. WildBill
    WildBill United States Active Member
    302
    111
    Central NY
    Exhaust cutouts often work on vacuum not pressure
    I'd expect that is a vacuum pump not a traditional air pump.
  3. StingerNYC
    292
    167
    Queens, NYC
    It is actually a solenoid for the vacuum lines. @Tobstertx3 (big thanks!) sent me the instructions for the JunB.L system and its nearly the same. The only difference is the JunB.L has a physical switch while Maintec is a remote. Install should be no problem now.
    • Like Like x 1
  4. KLR STINGER
    KLR STINGER Canada Active Member
    411
    292
    68
    how much was the maintec EVC exhaust?
  5. StingerNYC
    292
    167
    Queens, NYC
    1650 shipped from shark racing. Pricing was the main reason for purchase. $450 less than junb.l. I am just taking a risk on how it will sound. I will find out soon.
    • Informative Informative x 1
  6. Tobstertx3
    Tobstertx3 United States Active Member Texas Stinger Swarm
    249
    79
    Houston, TX
    Best of luck with the install @StingerNYC . Looking forward to hear your thoughts on it.
  7. TuscaniCustoms
    TuscaniCustoms Slovenia Active Member Authorized Vendor
    288
    86
    Pivka, Slovenia
  8. Jingguily
    Jingguily Latvia Newish Member
    17
    Maybe you could, you know, write some instructions.
  9. TuscaniCustoms
    288
    86
    Pivka, Slovenia
  10. robz32
    robz32 United States 1000 Posts Club! Staff Member Moderator Texas Stinger Swarm
    1,794
    789
    Houston, TX
    The JUN BL does come with instructions. In english.
  11. TuscaniCustoms
    288
    86
    Pivka, Slovenia
  12. MekstingerGT
    MekstingerGT United States Active Member
    207
    86
    You pay 1600 for something and doesnt come with intructions?!smh
  13. TuscaniCustoms
    288
    86
    Pivka, Slovenia
  14. STINGER
    STINGER Bahrain Active Member
    407
    214
    Bahrain
    One month later, so how does it sound and perform?
Draft saved Draft deleted
Share This Page
