Log check Map 0-3
FarmerMagnum
Hi All,
I know this is a bit of a big log, but it was a long drive and I didn't want to delete anything. I'd just like a second set of eyes on it. If the log is garbage I'll try and get a 3rd-5th map3 once I get a chance.
I've got a 2022 GT2
JB4
K&N Drop-Ins
Denso's at 22
Running E25ish mix (91+4gals E85)
Right at the beginning of the log is about a 10-80mph pull map3 if that gives enough information. 535-550 has a decent fourth gear pull too.
I seem to be pulling a max of 2.3dgs timing on all maps, However, my car does that on map 0 as well. 19psi is as high as I see the boost. At some points AFR seems pretty high under boost - not sure if that's normal.
Thanks for your help
Step one, set your JB4 to auto log at 80% throttle. That will eliminate the driving around :poop:. Doesn’t look to bad under boost though. Do a good 3rd thru 4th pull and lets have a look at that.
