Log check - hearing noises near engine
ICE_TT_3.3
Twin Cities X-Burbs
My car has been worrying me the past week or so making noises that are typical. I don’t know if I picked up a bad tank of gas or what. So far the noise has only happened on two separate days and at the same location so not sure if it’s even engine related. I can still build full boost and I kept the driving to maps 0 and 1 to be safe. No codes.
I might not have optimized my logging criteria with pedal set at 20 and up so hopefully these logs are ok and can tell if something might be wrong with my engine.
Edit: it looks like it grouped my logs I had about 4-5. Towards the bottom is the full throttle pedal position in various increments. I understand this may be a horrible log and if so I can get one tomorrow that is better.
Bump
Noises were just my underbody panel coming loose.
