LED Reverse Lights
Discussion in 'Kia Stinger Lighting - Inside and Out' started by derek0609, Feb 24, 2018.
  1. derek0609
    derek0609 United States Active Member
    110
    85
    Michigan
    Has anybody swapped out the halogen reverse bulbs for LEDS yet? I know it's a W16W/921 and I saw Walmart has Sylvania 921 LEDs for $15.
    • Like Like x 1
  2. DaJackson
    DaJackson United States 1000 Posts Club! Staff Member Moderator
    1,554
    642
    Louisiana
    Yup, I used LEDs from DeAutoKey.com. Had my entire GLI swapped to LEDs from them. Super bright and can tell a big difference in the backup camera.
    • Like Like x 3
  3. derek0609
    110
    85
    Michigan
    I assume access to the reverse lights is in the hatch. Any difficulties?
  4. DaJackson
    1,554
    642
    Louisiana
    Instructions to chsnge reverse lights are actually in the manual.
    Pop the hatch, pop two covers on each side of the hatch, remove 3 bolts in each side, unclip the wiring harnes for the lights, pull the whole assembly from the back of the car, twist the bulbs to remove, reverse steps to reassemble.
    The LEDs were a bit longer than the stock bulbs so I had to pull up some of the foam covering the back of the taillight to get more play in the wiring harness but once the bulbs were in the foam went back to its original position.
    • Informative Informative x 2
  5. Never thought
    Never thought United States 1000 Posts Club!
    1,244
    450
    88
    Arizona
    I had the dealer swap them out for me. Used 921/T10 sized Philips Ultinon LEDs. They are a little brighter than stock.
  6. westcoastGT
    westcoastGT 2500 Posts Club!
    4,871
    1,870
    Vancouver , Canada
    I have a set on order , here Wednesday . I'll post pre/post for reference .
    • Like Like x 2
  7. derek0609
    110
    85
    Michigan
    Thanks for the heads up!
    Thank you sir!
  8. Clearly Canadian
    Clearly Canadian Canada Stinger Enthusiast
    705
    223
    Edmonton Canada
    Doesn’t anyone have a pic of the stock reverse lights in action? I’ve never seen them because I’m always in the cockpit.
    • Like Like x 1
  9. derek0609
    110
    85
    Michigan
    Here’s my car with stock bulbs
    • Like Like x 1
  10. Clearly Canadian
    705
    223
    Edmonton Canada
    @derek0609 could you set up a mirror behind your car please? :laugh:
    • Like Like x 1
  11. DaJackson
    1,554
    642
    Louisiana
    • Like Like x 1
  12. eflyguy
    eflyguy United States 2500 Posts Club!
    2,563
    891
    Georgia, USA
    I have replaced all halogen bulbs with LED (and HID low beam) in my Sorento, and I had the first set of reverse lamps fail - which I hadn't noticed. So I bought replacements that I am really happy with, and now occasionally check the function of all my lights, either by reversing up to a typical glass-fronted store at night, or putting the car into reverse then turning off the engine.
  13. westcoastGT
    4,871
    1,870
    Vancouver , Canada
    Which brand did you buy to replace the failed units ? and which license plate bulbs did you use , I tried twice and both bulbs failed on my Sorento plates ?
  14. ballistic
    ballistic United States Stinger Enthusiast Founding Member Sustaining Member
    510
    169
    Orlando, FL
    @Clearly Canadian doesn't want to see how bright the reverse lights light up the area behind the car. he wants to see what the lights look like on the back of the car. so do i.
    • Agree Agree x 1
  15. derek0609
    110
    85
    Michigan
    I think I am going to tackle this in the next couple days and I will take pics of the process. Looking in the owners manual, you have to take out the entire center section of the rear lamp assembly to access the bulbs!
    • Like Like x 1
  16. DaJackson
    1,554
    642
    Louisiana
    It’s really not hard. 6 bolts and it slides right out, no clips or anything.
    • Like Like x 1
    • Useful Useful x 1
  17. eflyguy
    2,563
    891
    Georgia, USA
    I know this is a crappy pic, I took it while changing out the first failed LEDs for the new, and put one of the stock halogen bulb back in for this pic.
    Guess which side is which.
    These are the ones I used: https://www.amazon.com/gp/product/B0193ISBUA
    I'll need to do some digging to see which number plate light bulbs I bought..
    • Like Like x 1
  18. westcoastGT
    4,871
    1,870
    Vancouver , Canada
    Wow , the difference in minimal ! I'll say the drivers side is the LED ? Thanks for posting this and checking for the plate bulbs !! Much apprciated ! :)
    • Like Like x 1
  19. robz32
    robz32 United States 1000 Posts Club! Staff Member Moderator Texas Stinger Swarm
    2,441
    997
    Houston, TX
    Will be tackling this mod soon. Will makea new thread with pics comparing both halogens and LED.
    • Like Like x 1
    • Winner Winner x 1
  20. westcoastGT
    4,871
    1,870
    Vancouver , Canada
    My back up bulbs arrived : hopefully I'll find time to get them installed today
    • Like Like x 4
Draft saved Draft deleted
Share This Page
