Kia Stinger GT Rim Advice.
simmo1995
Hey guys, I was just wondering if I could get some advice, I have a 2018 Kia stinger GT, with
Front: 225/40/R19 - 19x8.0
Rear: 255/35/R19 - 19x8.5
Stock 19’ Kia tyres.
If I went for 19x8.5 rims for both front and rear with offsets of 35 or 38, would I be able to use the same tyres off my old rims on the new rims. Or would I have to purchase new tyres for my new rims, mainly just wondering if the tyre sizing would match up on the new rims. Also I’ve checked previously but just making sure, would 19x8.5s fit on both front and rear of my car without any issues arising?
you can put the oem tires on those rims and wear them out, then go square so you can rotate. ether offset that you mentioned will work too. the oem offset for square 18" setup is 34, as is the 19" front wheel on the staggered setup, so that offset is optimal. for comparison, I have 19" staggered 8.5 wide in front and 9.5 wide in back, and I use the michelin in oem sizes that you posted. my offsets with these wheels are 40 and 39 front and rear respectively.
