Keeping Back of Car Clean
l3arbarossa
Hi all, just wanted to see what people were using to keep the back of their Stinger's clean. I've noticed that after I wash and wax, the back end gets extremely dirty very fast from road debris, etc. For what it's worth, I do have a white exterior which I know is harder to keep clean, just didn't know if anyone had any tips or tricks I could use to keep it looking good. Thanks in advance!
westcoastGT
5000 Posts Club!
6,620
2,478
Vancouver , Canada
White exteriors show less dirt than darker cars , get some mud guards , they'll help a bit , but all cars collect rear dirt
ShannonC
1000 Posts Club!
It's a common problem along with door sills. I use a Meguires duster nearly every day.
JAI-STINGER
19
Orlando, FL
I have owned several white cars, but this car for some reason, the back gets extremely dirtier than the rest of the car. I just washed the car a couple of days ago and I noticed the next day the rear was filthy again.
TwiceStung
184
NC
Drive in reverse......quickly.
Flameangel
2500 Posts Club!
3,311
1,339
Geelong, Victoria
Must be something to do with the Fastback design, I have just had mud flaps installed so I'll see if that helps.
A person did mention that apparently a spoiler helps due to the different air flow created.
MerlintheMad
10000 Posts Club!
12,075
2,817
West Jordan, Y00TAW
Yep. The Stinger sucks dust into a dead air space and it lands on the rear panels (my theory:p). The duster is the best ongoing solution. And I've now added a 1" wide boar's hair brush to clean out around the exhaust stubs. When the dirtiness is pretty much adhered to the paint and the rest of the car still looks presentable, I will get a bucket of hot water and towel off the rear quarters then microfiber dry: usually to the top of the hatch window and to the forward edge of the rear wheel wells. Often, the rear looks good enough after dusting and brushing off, but there is a bit of exhaust fouling on the diffuser, and/or water drops dried on here or there. Once everything is dusted off, I'll go around with a spray bottle and microfiber and spruce up; spot cleaning, literally.
nhcowboy28
1000 Posts Club!
2,146
815
Alpharetta, GA
Try a hybrid ceramic wax (mother’s, mcguires, etc). I swear it keeps dust down not to mention rain spots.
Yes. I know this isn’t as good as a ceramic coating. But at 14 a bottle that lasts at least 6 full applications (and the fact you basically spray and hose off to apply)... very good results.
CVD
4
All cars get filthy in the back when driving on wet roads. It’s just a low pressure area sucking all the junk thrown up by your tires onto the back of the car. If it’s happening on clean, dry roads then I’d suggest it’s carbon from the exhaust. I’ve noticed the Stinger is dirtier than most cars in that regard and I’m not sure there’s a good solution to that.
CKeeler
210
Quail Valley, CA
My Mustang did the same thing. I’m kinda used to it by now. It’s annoying, but just something I’ve gotten used to seeing. My wife’s Mercury Milan doesn’t have this problem though. Neither does my Bronco
Paihan Lee
105
Irvine, CA
Yeah, the Stinger comes nowhere close to hatchbacks. I had a Golf TDI and that thing was so susceptible to collecting dirt and dust in the rear.
Rakker
168
Virginia
Yeah as someone said already, use a ceramic coating. It will still get dirty but not as dirty as it would otherwise and it will be a lot easier to clean off. I use Shine Armor Fortify Quick Coat and it works great!
MerlintheMad
10000 Posts Club!
12,075
2,817
West Jordan, Y00TAW
Gargamel
Sustaining Member +
484
155
Sweden
I have noticed that the back camera gets very dirty quickly, and the side ones takes a tad more but also gets dirty rather fast.
