Przemek
- Jan 28, 2018
Hi,
According to LOGs there is a problem with TRIMS (not TRIMS2). Which fuel wire (short having a resistor or a long one) is related to the TRIMS data?
When the wire having the resistor is measured by the resistance meter (from JB4 box pin 21 all the way to the posi-tap) should it show 1K ohm? I believe the resistor is 1K and I am not sure whether it is not broken.
