STINGER
What's the minimum clearance for those front calipers? I went with 18" Enkeis as "have some track fun" wheels, but it seems like they wouldn't clear these calipers, unfortunately..
Typically 19's and above because the rotors are significantly bigger. But some 18's I believe will clear. Attached are the diagrams for my brakes, you can check with Enkei if they will clear, you need to tell them which wheel and offset your are running and they should tell you if it will clear or not.
