Will I Am
I got the Red Injen Intakes and installed them myself. Passenger side went well - very easy. Driver's was a little more difficult, but more so do to a defective part. The larger pcv tube (12mm) would not line up without pinching the hose. The air filter was crammed so low it barely would go on due to the angle of the pipe being aimed downwards. Injen replaced the driver's side one under warranty. I installed the replacement and the air filter now goes on easier, but the 12mm hose is still having a problem kinking up - the bend is too tight. Has anyone else had this issue? How did you correct it? I am trying to find a 12mm molded hose with a 45 degree angle in it. Any suggestion will be appreciated. Thanks!![20210408_163330[1].jpg 20210408_163330[1].jpg](https://stingerforum.org/data/attachments/58/58512-824a6860b57c825e58e4aaed66faba3d.jpg?hash=REVzLB_ntp)
