" HUD not calibrated "
Hussain
greetings all I dont know if anyone has had the same problem,
Whenever I turn the HUD on it shows me the message: not calibrated.
Even though I tried to go to the. Sitting and change it a bit but the same problem..
Waiting for your help, thanks
Nothing in the user manual about "calibration." I'd try going into the menu and turning the HUD off. Then turn it back ON and make some changes to the display (such as changing the color.) See if it doesn't "reset." If not, take it to the shop under warranty.
Another option could be a problem with the speed sensor signal. The calibration maybe off and in turn it is throwing a bad reading on the HUD.
