How to install Wireless Charger on your Stinger
Discussion in 'Kia Stinger How To's and Do It Yourself' started by robz32, Mar 30, 2018.
  1. SilverNitr8
    SilverNitr8 United States Active Member
    312
    80
    Ashburn, VA
    Hey Neill, no worries. I was able to install it myself. Just had to build my confidence a bit, but it's all good. It wasn't as difficult as it looked.
  2. Neill Franklin
    Neill Franklin United States Newish Member
    13
    Baltimore, MD
    Well done! FYI, I’ve done quite a bit of add on work, from rear reflector LEDs to exhaust and intake. Let me know if you plan to do anything else.
  3. SilverNitr8
    312
    80
    Ashburn, VA
    Thanks! I appreciate it. What intake do you have on yours?
  4. Neill Franklin
    13
    Baltimore, MD
    I went with K&N. I've used K&N in the past and I like the look.
    • Like Like x 1
  5. SilverNitr8
    312
    80
    Ashburn, VA
    Nice! I'm actually thinking of getting it too. Did you have any fitment issues? I heard one of the clamps just needs to be replaced by a smaller one, but not sure if there were any other fitment issues beyond that.
  6. Neill Franklin
    13
    Baltimore, MD
    I had none, but you must be very careful when working with the plastic parts, which have the potential to break if over torqued.
  7. SilverNitr8
    312
    80
    Ashburn, VA
    got it. Thanks! I'm sold.
  8. Crewdawg130
    Crewdawg130 Germany Member
    51
    30
    Very helpful thread. Just finished installing mine. Less painful than I thought. And now that I’m done wireless charging doesn’t work. It will recognize it in the menu and everything else works just no charging. I even took the phone cover off and even the rubber pad in the tray. Nothing. Everything is connected. Any ideas?
  9. robz32
    robz32 United States 1000 Posts Club! Staff Member Moderator Texas Stinger Swarm
    1,538
    710
    Houston, TX
    what kind of phone do you have?
  10. Crewdawg130
    51
    30
    Xs Max
  11. Joseph Spiegel
    Joseph Spiegel United States Stinger Enthusiast Sustaining Member
    679
    252
    68
    Los Angeles, CA
    You’ve turned the phone in both directions? I’m thinking the sensor and coil aren’t aligning. I mean N and S not over, the back has to be down. Sigh. Also you’ve tested the iPhone on a known working Qi charging pad?
    Also, do you have access to another Qi enabled phone, any brand?
  12. Crewdawg130
    51
    30
    Gents. Is working. With the cover and the pad. In my exitment and ignorance did not know it doesn’t work with the door open lol.
    • Informative Informative x 2
  13. nhcowboy28
    nhcowboy28 United States Active Member
    196
    83
    Excellent!!
  14. Joseph Spiegel
    679
    252
    68
    Los Angeles, CA
    Wow, you mean you have to slide the cover closed for it to start charging? That’s a horrible design. The iPhone is going to get very hot.
  15. Crewdawg130
    51
    30
    No sir. I mean you have to have the car door closed
    • Informative Informative x 1
  16. Joseph Spiegel
    679
    252
    68
    Los Angeles, CA
    Wow, OK then, I guess that makes sense.
  17. DiabloStinger
    DiabloStinger United States Stinger Enthusiast
    646
    169
    Gilbert, AZ
    Just did a 25 minute swap to stock on the old car and am about to tackle the install again on the new one. Super easy to complete... Found you only need to remove the three bolts holding the console down on the gt1 and lower models. Makes it a breeze.
  18. MCGT2
    MCGT2 United States Member
    20
    12
    I am happy I found this! I just got my Stinger and hate that it didn’t have this like my other car. Ordered and gonna tackle soon as it comes in! I bought 2 Stingers, one for me and one for the spouse, so we will see if I can get away with doing stuff on mine only lol
  19. nhcowboy28
    196
    83
    Might as well do the Korean spec center console (with cup holder cover) at the same time... since you pull it out anyway!
  20. MCGT2
    20
    12
    Biggest difference is the cup holder cover?
Draft saved Draft deleted
Share This Page
