How To Convert Reverse lights to LED
Discussion in 'Kia Stinger How To's and Do It Yourself' started by robz32, Mar 1, 2018.
  1. robz32
    robz32 United States 2500 Posts Club! Authorized Vendor Texas Stinger Swarm
    2,950
    1,172
    Houston, TX
    • Like Like x 10
    • Informative Informative x 10
    • Winner Winner x 8
    • Useful Useful x 3
  2. SEA Stinger
    SEA Stinger United States Active Member
    452
    272
    68
    Seattle, Washington
    Excellent DIY directions, @robz32! These will be very useful - my LED backup lights are being delivered tomorrow!
  3. DaJackson
    DaJackson United States 1000 Posts Club!
    1,589
    666
    Louisiana
    @robz32 I think your label on the rear shot comparing stock to LED is backwards. Says LED is on the right but the pic looks like it’s on the left.
    When I did this I didn’t need to pry the light bar out, just grabbing it on both sides it slid right out.
    Also DO NOT use a screw driver or anything metal to pry the panels in the hatch. That plastic is very soft (as all interior trim is) and will damage easily.
    • Agree Agree x 1
  4. Falaris
    Falaris United States Active Member Sustaining Member +
    199
    187
    Virginia
    @robz32 Excellent write up! Thank you for the time and thoroughness.
    -Fal
  5. eflyguy
    eflyguy United States 2500 Posts Club!
    2,807
    954
    Georgia, USA
    I can't believe they would have an owner take out such a fragile part to change a freaking bulb! The cover on my Sorento exposes the bulb holders themselves, it's a 30 second job to change out. I even checked the Stinger owners manual and, sure enough, that's the procedure.
    • Agree Agree x 2
  6. derek0609
    derek0609 United States Active Member
    111
    86
    Michigan
    I thought the same thing.
  7. Brian Keenan
    Brian Keenan United States Active Member Founding Member
    218
    73
    LA, CA
    Great writeup! Thank you very much! Looks great!
  8. robz32
    2,950
    1,172
    Houston, TX
  9. Paul @ K8 Stinger Store
    Paul @ K8 Stinger Store United States Stinger Enthusiast Authorized Vendor
    574
    258
    68
    Raleigh, NC
  10. robz32
    2,950
    1,172
    Houston, TX
  11. derek0609
    111
    86
    Michigan
    Here are the bulbs I used, definitely brighter than stock and only a hair longer.
  12. SEA Stinger
    452
    272
    68
    Seattle, Washington
    Okay, I finally got around to replacing my reverse lights. Followed @robz32's outstanding DIY directions and photos. The process was a breeze, and the results are a definite improvement.
    I installed the same bulbs that @derek0609 did: Sylvania Zevo 921's. The package indicates that each LED "bulb" is 2.5 watts. The stock incandescents are 16 watts each. That implies the LEDs produce about 15% more lumens, but to me the difference seems more than that.
    @robz32, thanks again for your excellent installation guide!
    • Like Like x 3
    • Agree Agree x 1
  13. BIGRED
    BIGRED Canada Active Member
    Great post! Thanks for the detailed instructions! Will have to add this to my Stinger’s “to do list”
    • Like Like x 1
  14. Berzerker
    Berzerker United States Active Member
    424
    Just want to say that I did this today and the end result is amazing. Just some notes regarding the swap:
    - Once I unbolted the 6 bolts, the light bar came out so easily that I didn't even need to pry anything. Just pop one side out a bit, pop the other side out, then the whole thing slides out very easily.
    - For prying out the plastic guards inside the trunk, I found it easiest to go around the bottom instead of the top when making your way around popping it out, it'll work out easier.
    Some pics:
    Alone:
    [​IMG]
    Full taillights:
    [​IMG]
    • Informative Informative x 3
    • Like Like x 1
  15. Rango
    Rango United States Stinger Enthusiast
    990
    861
    98
    Memphis, TN
    Changed out my reverse bulbs today also. Nice white lights backing up now. Huge thanks to robz32 for a great DIY post for the switch. On to the next mod ... window tint tomorrow:thumbup:. 20180318_141813.jpg
    • Like Like x 3
  16. Thang
    Thang United States Active Member
    141
    56
    Huge issue with my install. Had no issues taking out light bar and installing the bulbs. Issue is that I used the bulbs that RobZ32 recommended, and the LED Reverse Lights won’t shut off. In Neutral, Drive, and Park, the bulb constantly stays on. I replaced an LED bulb with one of the LED spares it came with (4-Pack) and same issue. Replaced one of the two bulbs with halogen and it worked correctly. Made both LED bulbs again and same issue, constantly on. I reverted back to the stock halogen bulbs. Something similar happened to my 2017 KIA SPORTAGE SX. It won’t let you shift out of park when the reverse bulb is replaced with LED. Will just order white halogens.
  17. BIGRED
    Anyone else having this issue? What type of bulb are you using?
  18. robz32
    2,950
    1,172
    Houston, TX
  19. Thang
    141
    56
    I'm familiar with polarity and I have modded the lighting in all 5 of my cars in the last 7 years. It happens when both are LED. No issues when one is halogen. Similar to my 2017 Sportage except that wouldn't even let me shift out of park. The Stinger will let me shift out of park but again the bulbs are on 100% of the time. Oh well, appreciate your walk through though.
    • Friendly Friendly x 1
  20. Thang
    141
    56
Draft saved Draft deleted
Share This Page
Users found this page by searching for:
  1. how to invert an led
