How often does your radiator fan run?
Discussion in 'Engine, Drivetrain, and Exhaust Discussion' started by UltraCow, Dec 4, 2019 at 8:10 PM.
  1. UltraCow
    UltraCow United States New Member
    2
    2
    As the thread title says, what do most of you guys see for how often your radiator fan runs? Around town, just off the freeway, stop-and-go, etc.
    From my observations so far, it seems that the cooling system on the Stinger is fairly aggressive in trying to keep *something* in a certain temp range most of the time, whether that's for oil cooling, intercooler airflow (not sure if the fan shroud is even connected to it), or simply coolant or engine bay temps. This is during a fairly cold California winter, with plenty of "normal" driving as well.
    For reference, I've had a few different stock FI cars along with NA (my Stinger is the 3.3), so I do some data points here for something with a turbo or two vs not.
  2. NS_Stinger
    NS_Stinger Canada 1000 Posts Club!
    1,014
    295
    88
    In the summer months I noticed that it ran often which doesn't surprise me being that it's a twin turbo car and produces a lot of heat.
  3. MerlintheMad
    MerlintheMad United States 5000 Posts Club!
    9,438
    1,981
    West Jordan, Y00TAW
    I just assumed that the radiator fan runs more or less constantly. And I don't even think about it.
  4. oddball
    oddball United States Active Member
    195
    55
    We only have one fan, so it'll run any time the A/C system is running too. The A/C compressor might be pumping while you have the heat on in order to de-humidify the air. That helps prevent fogging on cold days.
    Plugging in a high quality scan tool should give you the data you want.
  5. Michael Polito
    Michael Polito Canada Newish Member
    17
    4
    ALL THE TIME, and its loud... when i go for my first oil change im going to ask about it
    also im from toronto so its cold here and still runs like crazy
  6. Whytiptoe
    Whytiptoe United States Member
    Nashville, TN
    As oddball said this is also used for the AC system. Next time you hear it running turn your AC/Heat off and see it stop. I thought the same thing like WTH and happened to turn the heat/air off and the fan followed to the off position, turned the heat/air back on and the fan followed again.
  7. Michael Polito
    17
    4
    ac lol its freezing here in toronto. -10c// 14 f
    even with heat off it runs after driving for a bit
    • Funny Funny x 1
  8. Whytiptoe
    Nashville, TN
    Now I know the car has an auto defrost system even with the air/heat in the off position. Might check and see if you have that setting on and see if the possibly is the culprit.
  9. 5tinger
    5tinger Australia Member
    86
    10
    All Kia Hyundai's use a single fan that I have never noticed kick in as they're so quiet.
    If you want to hear fan noise - Toyota/Lexus use twin-fans that you can hear from a mile away - they're so loud & powerful that they make the entire vehicle vibrate for a second when they run.
  10. BertBert2019GT
    BertBert2019GT United States Active Member
    369
    241
    Centreville, VA
    wait, yours turns off?!
    • Funny Funny x 1
Draft saved Draft deleted
Share This Page
