HK crossover settings
Yahya khan
I have recently installed RF P1 by tapping into subwoofer wires. Only problem I have now is no mid bass. If I tap into speaker wire it will not have any low bass(speakers crossover around 75Hz). So my question is if it's possible to change crossover settings for HK system so we can fully customize the system. Do we have the option to change crossover settings for entire system?
2 options:
1) set the rockford crossover higher. I know they are crossed at around 80 Hz they still retain some midbass signals.
2) install another 4 channel amp for all the door woofers and turn it up. A lot of work involved to install and hide the amp.
3) better option is to change the mids (+/- the tweeter) at the door (refer to my trend Change Harman Kardon midrange speakers Kia Stinger the new high quality mids is less efficient, you can just turn the volume up to gain between 6 to 10 db of midbass.
