Ok I have 2020 stinger gt awd. I was trying to find source of a noise that was coming with factory 19 Inc rim tyre set up. Turns out a slightly bent rim so I replaced those with new set of 19 rims (19-8.5 front 19-9.5 rear) and tires. I also got an alignment done in that process even though there were no notable issues with the alignment. According to first shop it needed little bit adjustment but then it made my steering slightly crooked to the left. Then I went to second shop and they also said it was off made adjustments. Then that made my steering wheel crooked to the right and made the car even worse than first shop. So I went back to first shop and settled on final alignment and it’s still not as good as what I used to have.
I attached both specs from the shops here. Black and white sheet is from first shop and colored sheet is from the second shop. Can anyone suggest what to do in this case. Should I just go to a dealer.
