GTS rear LSD into a GT AWD
Jrob81
Can you get a standard Rwd limited slip and change out ours?
or if the LSD from a GTS will fit in ours and purchasable through Kia ?
or if the LSD (Limited Slip Differential) from a GTS will fit in ours and purchasable through Kia ?
"GTS D-AWD Stingers also get a standard limited-slip differential, previously available only on the RWD Stinger, and Kia says that it has changed mapping for the transmission, stability control, and steering to work with this new system."
From C&D last year. (I'm too newb to post a link, so I advise the use of Google)
Could swap and ask for the GTS mapping from Kia?
