Gts ecu/LSD (Limited Slip Differential) in a gt2 awd?
Caylin Bolin
Will a gts ecu work on a gt2 without losing all the bells and whistles? I need an lsd in my awd because i need to get sideways lol but i also needed all the bells and whistles..... if i swap the gts ecu in my gt2 and an lsd from a gts will everything work as it should?
It will not. You will loose support for a lot of the feature found on the GT2 that are not present on the GTS. Not to mention the fact that you will need to source a transfer case with LSD
LSD wont help you get sideways. In fact it will do the exact opposite, it increases traction.
If you want to get sideways in your AWD just pull the front diff fuse.
LSD (Limited Slip Differential) wont help you get sideways. In fact it will do the exact opposite, it increases traction.
Open diff is lame as hell lsd is more fun and itll help it climb sideways... as is with this open diff bs itll always just try and straighten out...pulling the fuse will make it 100% rwd but that doesnt make it fun...lsd makes it fun ive had many vehicles with both and i am 100% for the lsd over the open diff... as an example not 1 drift car has an open diff i know its not a drift car but with and lsd itll at least climb sideways when i want it to... also the traction control/stability control never fully turns off... which is why i also need a kit that will do that just like the gts but in canada its not available
