Yesterday I took my car to a Tire Kingdom for an alignment. During the alignment, they noticed that the front left brake caliper is leaking from the washer that connects the brake line to the caliper. They replaced the washer and introduced air in the system. It took them 5 hours to bleed the system as they only bled it from one exit line instead of two on each caliper. After properly bleeding the system, the c2402(1) code came up. They tested it by initiating the ABS bleed procedure and told me that the ABS motor is working. Any ideas what might cause the issue and how to fix it. According to them, their 1000 autel computer can not read the codes....
I replaced the front left wheel abs sensor about two months ago and the light galore on the dash went away...it's back now.
