Gear shift problem
Discussion in 'Engine, Drivetrain, and Exhaust Discussion' started by DenisG, Apr 3, 2018.
  1. DenisG
    DenisG Australia Newish Member
    Mt Eliza,Australia
    Intermittently I find that changing into D or R, it drops into N
    Can cause problems sometimes especially in car parks
    Anybody else have the same problem. My 2.0 GT line only done 5600km's
  2. mldavis2
    mldavis2 United States 1000 Posts Club!
    1,266
    602
    Neosho, MO
    Sounds like a minor cable adjustment. Warranty check. Make sure you press the button on the shifter.
  3. Luminary
    Luminary United States Active Member Staff Member Moderator Sustaining Member +
    380
    360
    68
    Northern VA
    Funny you should post this.
    This morning after sitting in gawd awful traffic for more then an hour, I drove into work and pulled into a parking spot. Did like I always do, shift to park, pushed the Engine Start/Stop button and took my foot of the break and then wondered why the car next to me was backing up without a driver. Only to realize it was me rolling backwards. Looked at the dash, and it was telling me to put the car in park. I looked at the gear shifter and it WAS in park. Was a bit scary.
    I had to shift back to drive and then back to Park for it to register the car was in park. First time for this, and I keep looking out the window from my office to make sure the car is still in it's spot.
    • Informative Informative x 1
    • Useful Useful x 1
  4. Kamauxx
    3,178
    1,255
    GT2?
  5. Luminary
    380
    360
    68
    Northern VA
    2.0t Premium
  6. mldavis2
    1,266
    602
    Neosho, MO
    The owners manual says not to use Park without also engaging the Parking brake.
  7. Kazz
    Kazz United States 1000 Posts Club! Texas Stinger Swarm
    1,203
    418
    88
    Illinois
    I have a GT2 and have thought I'd put the car in Park or D or R and gotten Neutral a few times. I'm used to slapping at a stick, I guess. I've become much more deliberate after I've had a couple of near-issues.
  8. mldavis2
    1,266
    602
    Neosho, MO
    Yes, you definitely need to "think" when changing directions with the DBW shifter. That's one reason I wanted a GT1 instead of a GT2 although I am getting used to the fancy shifter. I just have to remember that it's always parked in the middle of the PRND(L) range instead of the top.
  9. DenisG
    Mt Eliza,Australia
    Thanks. I do press the button on the shifter.Calling in to dealer today to book in for Warranty check
    • Like Like x 2
  10. DenisG
    Mt Eliza,Australia
    Visited my Dealer Kia Mornington. Only need to press the button on the shift when putting into R and there is a slight lag. Don't need to press button when shifting into D. Resolved.
  11. Kazz
    1,203
    418
    88
    Illinois
    I just realized today that my problem is not releasing the button quickly enough when shifting into Reverse. If I'm late I end up in Neutral.
  12. Trillium
    Trillium United States Newish Member
    6
    10
    Have you had any issues since? I find that My GT2 tends to slip to N from both R and D on seldom/random occasions. In order to get the car to engage in D, I have to place the car in Park and try again. I haven't taken it to the dealership as it doesn't replicate easily and I don't want them to think I'm crazy....
  13. Sensibly Spirited Driver
    Sensibly Spirited Driver United States Active Member
    191
    59
    Seattle
    This sounds quite troubling. Interesting that it's the 2.0L. Hopefully it can get sorted quickly. And, as another poster mentioned, always use the parking break when parking. I miss having an ebrake stick. For a high performance car, you should have an ebrake that you can engage while driving. Let us know what happens at the dealer.
  14. DenisG
    Mt Eliza,Australia
    Yes,every now and then get N. I hold for a second or two and make sure the D or R is in the bottom section .
  15. Trillium
    6
    10
    I'm hoping to get the car to the dealership in the next couple weeks. I'll post an update if I learn anything useful.
  16. BlueGT
    BlueGT Bulgaria Member
    45
    29
    I’ve hade it happen a few time as well.
  17. DenisG
    Mt Eliza,Australia
    Cable?? It's electronic !
    • Like Like x 2
  18. mldavis2
    1,266
    602
    Neosho, MO
    Sorry, not familiar with NZ trim nomenclature. Saw the 2.0 and was thinking of the 2-liter. If it is actually the top trim level (GT2 equivalent) then yes, it is a solenoid shifter. The top is nice and flat and slightly padded so it's a good armrest at times, but it is also easy to move the arm and drop into N if you aren't paying attention. I've done it.
  19. Kazz
    1,203
    418
    88
    Illinois
    Something I've been working on, besides being a bit more deliberate about moving the shifter, is to concentrate on releasing the lock button when pushed forward (Drive), or back (Reverse). It's all about when you release the lock button on the side of the shifter, I think.
    • Like Like x 1
  20. mldavis2
    1,266
    602
    Neosho, MO
    Yes, too fancy and not necessary IMHO. That's one reason I initially tried to get a GT1. I'm getting used to it.....
Draft saved Draft deleted
Share This Page
Users found this page by searching for:
  1. can you stick shift with stinger gt2
