Hello, all. While installing my intercooler I ran into some difficulty as far as the connection between the bms intercooler and the stock piping with the tension clamp on the driver side. Currently, I assume I am unable to insert the fitting fully, as I can only get the shoulder of the fitting seated. I assume that the tension clamp is supposed to be locked into the slot of the fitting. Has anyone run into this issue previously?
