Fuel Wires installed correctly?
waffles
Huntsville, AL
Ive got everything installed, JB4 is working as intended, and I bought some Plug-and-Play adapters for the fuel wires. I am wondering how to tell (from the logs possibly?) if the fuel wires are installed and working correctly. Any help here would be greatly appreciated.
Look at fuel trims vs. fuel enrichment. Trims should be close together bank to bank and drop as fuel enrichment increases.
Since im unsure what over half the columns in the log mean, would i be right in assuming im looking at 'fuelen' as the fuel enrichment and 'trims'/'trims2' as the fuel trims?
With that as the assumption, my 'fuelen' is 0 throughout the whole spreadsheet, so i assume that the fuel wires are not properly making contact? (Im on Map1 if that changes anything)
