3.3TT Fuel System Cleaner
Discussion in 'Engine, Drivetrain, and Exhaust Discussion' started by init3, Jul 12, 2018.
  1. init3
    init3 United States Member
    30
    11
    What are your guys thoughts on using something like this?
    I searched our forums and haven't found much on this topic.
  2. MerlintheMad
    MerlintheMad United States 2500 Posts Club!
    4,782
    948
    West Jordan, Y00TAW
    I seem to recall reading in the manual that additives and cleaners are not recommended. Why would you even think that your brand new car needs a cleaner? Not for many years.
    • Agree Agree x 1
  3. SteveCo
    SteveCo Canada Stinger Enthusiast
    956
    350
    68
    Calgary, AB
    Actually, Service 2 on the Kia maintenance schedule I got from the dealer has adding Kia fuel system treatment as one of the items. As our climate is considered severe service, service 2 is at only 12 months. :unsure:
  4. Stinger GT SS
    Stinger GT SS Australia 2500 Posts Club!
    3,140
    1,075
    Sydney, NSW
    Dealer did my 10,000kms Service last week & used “Genuine Fuel Additive (Injector Cleaner)”
    It surprised me but if Kia use it who am I to argue.
    • Agree Agree x 1
  5. Volvowith18psi
    Volvowith18psi United States Active Member
    173
    53
    No.
    These cars are brand new. Use top tier gas (google it) ALWAYS.
    Can I sell you some blinker fluid? lol...
    Do not get upsold.
    • Agree Agree x 2
    • Like Like x 1
    • Funny Funny x 1
  6. eflyguy
    eflyguy United States 1000 Posts Club! Staff Member Moderator
    1,923
    683
    Georgia, USA
    I'd worry more about the muffler bearings, they're not made like they used to be!
    • Funny Funny x 2
  7. StingerNYC
    StingerNYC United States Active Member
    292
    167
    Queens, NYC
    • Like Like x 1
  8. MerlintheMad
    4,782
    948
    West Jordan, Y00TAW
    Ah, that's the passage (like scripture, it is). Not "many years", but many thousands of miles. And get Kia's recommended brand(s). I wouldn't be using lower grade gasoline anyway, so I don't expect to encounter any engine performance issues.
  9. SteveCo
    956
    350
    68
    Calgary, AB
    As I'll be doing my own maintenance after having the dealer do the first 6 Mth/6,000 KM (Service 1), I'll be putting in the fuel additive at service 2 (12 Mth/12,000 KM) per the prescribed maintenance schedule - to ensure that all the warranty requirements are met.
    • Agree Agree x 2
  10. Coltt
    Coltt Canada Member
    40
    10
    Sherwood Park AB
    At least in the prairies up in Canad it's done every 12,000 with the maintenance packages (2,3 & 4) even if you use premium fuel, build up in the fuel system will still occur just slower and in smaller amounts. While it might not be needed right out of the away, as you put miles on the car it will help
  11. Mach_Tuck
    Mach_Tuck United States 1000 Posts Club!
    1,025
    259
    88
    Phoenix, AZ
    The Stinger Tech i spoke with at the dealer said they add to the tank and also add to the vacuum system. Tank method cleans the injectors and vacuum method cleans the intake valves...since GDI.
    He basically told me it was a commercial version of the SeaFoam fuel system cleaner stuff.
    Adding to the vacuum line seems more important for the intake valves in my opinion.
    • Agree Agree x 2
  12. SteveCo
    956
    350
    68
    Calgary, AB
    That's the part I'm interested in - fuel additives do nothing for the valves with a GDI system. Kia (and others) had teething problems with this, when it showed up as an issue after GDI vehicles starting racking up some mile.
    Interesting that he referenced Seafoam - I used that on a motorcycle with recalcitrant Mikuni carbs and it worked wonders. Thanks for the info - I'll have to give the vacuum/intakes a shot when that service interval rolls around.
  13. Mach_Tuck
    1,025
    259
    88
    Phoenix, AZ
    Hopefully a Oil Catch Can will mitigate "most" of the intake valve caking but a cleaner into the vacuum would certainly be beneficial. Better than having to walnut peen the valves later on down the road!
  14. SteveCo
    956
    350
    68
    Calgary, AB
    Here's a useful Seafoam video on the application method for a turbo GDI engine.
  15. Stinger GT SS
    3,140
    1,075
    Sydney, NSW
    It wasn’t an up sell....it’s part of the logbook service, the dealer has to seek approval from the customer to carry out any works above & beyond the stated service. As I was not asked this is part of the service the same as oil & filter change, so I’ll pass on the blinker fluid thanks...:thumbup:
  16. Kamauxx
    3,465
    1,357
    So would you need to spray an entire can per turbo?
  17. SteveCo
    956
    350
    68
    Calgary, AB
    No, the spray is injected downstream from the turbos and intercooler, just before the (single) throttle body.
    • Informative Informative x 1
  18. Socalstinga
    Socalstinga United States Active Member
    383
    88
    They asked me on my first service at 5k per the manual. I declined, still a bit early.
Draft saved Draft deleted
Share This Page
