I've been running map 2 for a couple of years now. I don't have E locally. Stopped, out of town, today to fill up and they had E. So I put 4 gallons in and topped the rest off with 93. I did a couple pulls on map2 and map3. I couldn't feel a difference. Can someone corroborate my butt dyno by looking at the attached logs?
Did you reset your ECU after adding the E? You have some timing being pulled in map3 so the difference is small between the two maps. Maybe getting a little more boost in map3 on these logs.
He's right, you've got some timing being pulled. Keep in mind, these ECU's are adaptive and it will take a few days for everything to settle where they are supposed to be. Drive the car normal and post again in a day or so. Meanwhile, I would update your firmware. You are on 22 and I believe 28 or 29 is out now. Many improvements and worth keeping up on that.
