E98 with JB4
GTA Jay
Bradford
Anyone here run e98 in their stinger? Are you blending it to an e30? What are your thoughts on it.
The place I source from is out of e85 but has e98 for the same price.
Up to E40 can be used currently. Higher mixtures will require a high pressure pump upgrade or CPI, and a back end flash map.
so if my math is correct, 5 gallons of e98 with 11 gallons of Shell 91 e0 should net me e31. And this should work well with maps 3/4
Yes 5-6 gallons is the usual mix per tank.
