Door spot lamp
Discussion in 'Kia Stinger Lighting - Inside and Out' started by Tinter, Jun 7, 2019.
  1. Tinter
    Tinter Australia Member
    34
    34
    Ringwood, Melbourne
    I’ve got family holidaying in Seoul atm and I’m trying to get them to buy this item by visiting a Kia car dealership.
    They were told “they don’t have it” yet it’s a genuine part by the look of it on Ebay.
    Is it a USA item only and made solely for that market?
    It’s certainly not available in Australia.
  2. Tinter
    34
    34
    Ringwood, Melbourne
    No one ever fitted it anywhere?
  3. SilverGT
    SilverGT Australia Member
    21
    19
    Melbourne, Victoria
    Dealerships never stock anything! Always has to be ordered.
    This item would actually quite easy to install, assuming the Australian wiring loom has a connection for it? It may not! I’ve removed the door panels and don’t remember seeing any spare connections. If you had to run your own wiring then that would be a bit more of a challenge.
  4. Stinger GT SS
    Stinger GT SS Australia 2500 Posts Club!
    3,772
    1,401
    Sydney, NSW
    Found this on eBay delivery is out of South Korea
    OEM KIA Stinger 2017 -2019 Door Spot Lamp | eBay
  5. AV8R
    AV8R Australia 5000 Posts Club! Staff Member Authorized Vendor Moderator
  6. Stinger GT SS
    3,772
    1,401
    Sydney, NSW
    The hole will be at the bottom so if gravity does it’s job water will get out instead.....:rofl::rofl::rofl:
  7. AV8R
  8. Bigbikes
    Bigbikes Australia Member
    78
    60
    Melbourne Victoria
    You can put it in door trim use pwr off existing lamp, I did this in a ford i had simple as
  9. robz32
    robz32 United States 1000 Posts Club! Staff Member Moderator Texas Stinger Swarm
    2,257
    939
    Houston, TX
    Certainly not a US only thing. It is actually a Korean only option. It came on the TUON edition in Korea, so Im not surprised that they don't have it in stock.
    As for installation is very easy and straight forward, the whole that you need to drill is not that big and will not be visible, as it is at the bottom of the door card, no water will flow through or touch it. It comes with a plug and play harness so there is no need to cut or tap into any wiring.
    • Informative Informative x 1
  10. Tinter
    34
    34
    Ringwood, Melbourne
    Exactly the situation!
    Can you elaborate on what is a TUON edition?
  11. robz32
    2,257
    939
    Houston, TX
  12. StingaGT
    StingaGT United States Member
    85
    Ann Arbor, MI
    In Korea, you need to visit place called "Mobis" to purchase parts for Hyundai, Kia and Genesis.
    Mobis is part distributor for Hyundai/Kia/Genesis, just like Mopar for FCA (Forward Collision-Avoidance Assist).
    • Like Like x 1
Draft saved Draft deleted
Share This Page
