Door ajar when closed
MasonK
So I had some problems last night with my car, figured out what it was but while I was solving that problem I had to disconnect my negative battery terminal l (I have a discussion post about that) and now my driver back door just shows that it’s open. Obviously this is an electrical issue as it was just fine before disconnecting the battery. I really don’t know why this happened. A blown fuse? I really don’t want to go to the dealership if it’s something like a fuse. There is a post similar to this but never seemed to be resolved. And yes I have disconnected the battery again to see if it would go away and that did not work.
2018 kia stinger gt2 Awd. Door ajar when the door is closed. Changed the door lock actuator with oem sealed part and still having the same issue.
