Does anyone use a wotbox in Stinger?
seo
I installed the N2MB WOTBOX on Kia Stinger 3.3t
But one problem is that during lunch control, the ignition cut, and the misfire is coming up, and the warning light is coming in
If you have a friend who uses WOTBOX in Stinger, can you share the program setting value?
wot box! best way to wreck everything
I installed one, but quickly removed it. They work great on traditional motors but this closed loop ECU freaks out. In park or neutral it worked great, but trying to build boost was a disaster. It would rev to the prescribed RPM and build boost but as soon as you let off the brake the ignition would cut, throttle would close, it was the worst mod I tried. I truly believe that this platform won't play nice with that box. As far as wiring, it was a nightmare too, between getting at the brake signal, the throttle position, and the ign wires under the fuse cover it's not something I would recommend to anybody. A good TCU will take care of all that.
