19’Stinger
- Nov 2, 2025
Hello,
I recently purchased a 2019 GT2. The front collision system stopped working, code p0597 and p0335. The first code was for thermostat heater control. The second one was for the crankshaft sensor. The car had no run ability issues or starting issues. The other day it would not crank. Had it towed to a shop. Finally after a week and a half they looked at it. They first said the engine was seized as it would not turn over by hand. I asked them to look at it more. The where able to rotate the engine backwards then back forwards and heard a scraping noise. They pushed it into the shop. Upon rasing the car on the lift the technician found holes in the transmission bell housing. The crank position trigger wheel had damage. Anyone heard of this issue and what was the cause??
