Coolant smell?
Discussion in 'Engine, Drivetrain, and Exhaust Discussion' started by Adamdan, Feb 22, 2019.
  1. Adamdan
    Adamdan Canada Stinger Enthusiast
    518
    110
    I’ve smelled Coolant since my stinger was new. I notice it more when I’ve driven the car hard. I never smell it in the car but I can get a hint of it when I open the door or stand near the hood. I have not seen any leaks or loss of coolant. The car has 5000km on it now. Do you guys notice the same thing? My 2015 rubicon had a bit of a coolant smell as well and same with my genesis r spec v8. I’m guessing it’s just the way the coolant system works and it’s just the smell from the breather.
  2. Joeygt
    Joeygt Australia Newish Member
    17
    5
    Sydney Australia
    I’ve noticed the same thing with mine. I monitored it for a little while, but found no leaks or loss of coolant. I’ve done over 7500km and it seems to be less noticeable now. Or maybe I’ve just gotten used to it.
    I wouldn’t worry about it though.
  3. washguy
    washguy United States Stinger Enthusiast
    665
    245
    Big D Yall
    Ive posted about this too.....no leaks...no nothing ,but my office is near the garage and I get whiffs of it even in here....when the car is run hard even more so....just 2 days ago the Wifey took it out....so shes pulling into the garage and I go open the door as she comes to a stop....its 45 degrees out and the auxiliary fan is running, and not only do I smell antifreeze,but freakin burnt rubber too! So I ask her whaats up at the grocery store, and why is there a burnt rubber smell coming off the car? She just giggled ...and said nevermind just get the groceries out of the car! Yes Dear :) Wash
    • Funny Funny x 2
  4. Jetstream
    Jetstream United States Newish Member
    10
    1
    Northern California
    Popped the hood after a short drive on a 3500 mile car after being told my car was making smoke during hard acceleration and thought hmm, smells like coolant. But, no sign of a leak. I didn’t check the condition of the oil, yet but 3500 miles is way too soon for a blown head gasket. Has anyone had similar problem at such a young age on the car? What did Kia do to solve?
  5. Adamdan
    518
    110
    My car and many other people that I have talked to have a bit of a coolant smell right after a drive near the front of the car. It seems to be just vaper through the breather of the coolant system. Both of my Genesis v8 sedans and my 2015 rubicon did the same thing. I read some of the newer coolants have a very strong smell. As long as your not loosing coolant you are probably ok. The smoke they saw could have been lots of thing. The stinger runs really rich at full throttle so that could be one thing.
    • Informative Informative x 1
  6. DiabloStinger
    DiabloStinger United States Stinger Enthusiast
    820
    216
    Gilbert, AZ
    My best guess is stock turbo seals are just like any other stock turbo.. weak. That smoke is most likely a mixture of oil and coolant on that surface, thus the smell without a leak. I've noticed it occasionally as well and attributed it to hard driving and some seal bypass.
    • Agree Agree x 1
    • Winner Winner x 1
  7. Jetstream
    10
    1
    Northern California
    The heck... does this go away after a while?
  8. SteveCo
    SteveCo Canada 1000 Posts Club!
    1,040
    396
    88
    Calgary, AB
    Spray your windshield washers and make sure that isn't what you are smelling. The factory fill WW fluid has a very strong smell that is very similar to that of glycol coolant.
  9. Jetstream
    10
    1
    Northern California
    Hmm. I had used them. I never thought to sniff the wiper fluid though. I was just correlating smell and smoke that the person following me to the shop had seen because the first place I went to in my mind was a dicked up head gasket...
  10. SteveCo
    1,040
    396
    88
    Calgary, AB
    Trust me, you won't need to get out of the car to smell it - the smell is quite evident as soon as it sprays. Relief is only a few dirty windshields away ... :p
  11. DiabloStinger
    820
    216
    Gilbert, AZ
    If it is turbo seals the smell doesnt go away without a new seal/turbo. The smoke from toasted seals will be very acrid and white/bluish out of the exhaust. It literally burns your nose and smells like nothing normal.
  12. Jetstream
    10
    1
    Northern California
    I noticed it smelled faintly of exhaust when I had -recirc- on.
  13. DiabloStinger
    820
    216
    Gilbert, AZ
    That is nothing more than the wind blowing the wrong way.
  14. Jetstream
    10
    1
    Northern California
    I was going 75 mph
Draft saved Draft deleted
Share This Page
