I wasn't sure if the mass airflow sensor was going to mess with itPerfectly safe, won't throw any codes. The main difference with open air boxes will probably be hearing the turbos spool. In theory reduced intake restriction will help you pull air sooner/faster, but without a tune don't expect much peak gain since boost is electronically limited.
To the extent they allow more airflow, the MAP/TMAP sensors will meter it and the car will add appropriate fuel. But you won't make more power because the car will open the wastegates once you hit max boost.I wasn't sure if the mass airflow sensor was going to mess with it
thank you very much for that!
