Coasting not working in eco??
I just try to keep the revs below 3000 until the Oil Temperature gauge is past the word OIL, which is a while after the water temperature is almost up to normal. Just trying to look after my turbos :)
i dont see the word errl...i see these things...maybe you are gt2 and its different than gt1...
I find that if you turn off CC, coasting will not engage. Sometimes other things will lock it out also. If you pull the right paddle to shift to 8 then hold it again to get back to D then tap the gas, it will start coasting.
Not that I use this much, but as an engineer, I have to 'push all the buttons' and know what they do.
Yup. Sport mode is waybtoo agressive for daily drive.
