kia stinger store
Climate control default setting?
GregS
88
Each time I power up my missile, the climate control reverts to 22.5c, I would like it to hold at 21.5, looked at the manual and searched the forum, can't find any mention of this?
ShannonC
2500 Posts Club!
Seems odd, mine stays as set on both zones.
GregS
88
Have not been driving much because of COVID, but yes my climate control setting keep reverting to 22.5 when the car us restarted the next day, this is really odd because I presume this is all software controlled and the software should be the same in all the MY21's???
vipeboy2000
396
68
Middle Tennessee
hmm.. that is odd, almost like something is resetting the computer.. mine also stays the same temp as previous shutdown.. has never reverted to a different temp or setting. Mine is a 2020 US model so pre facelift but i wouldn't think the climate control system changed much..
D.J.
124
How are you starting the car?
KIA UVO app? - the app has temperature presets that are user selectable.
Remote starter Keyfob?
Push to start button on dash?
new kia badge emblem logo
The best place to buy Kia Stinger modifications is at KDM Warehouse dot com! The official store of Kia Stinger dot com...
GregS
88
50/50 Push button/Key fob, we don't have UVO in Oz.
I'll pay attention to see if one works and the other doesn't.
n8hegr8
38
manual says to keep it on 73f / 22c auto, something to insure it maintains proper moisture inside cabin...its somewhere in the manual.
if you're remote starting, then it will use whatever temperature you have set in the UVO app.
GregS
88
No UVO in Oz.
5tinger
87
The issue with Auto is that the A/C always engages even when it's not necessary. Continues A/C use will lead to mold in the evaporator coils. Unless your switching off the AC and drawing outside air for a few minutes before shut off.
JamesNoBrakes
300
68
North
Are you cereal?
GregS
88
Ok, so I have been paying attention and confirmed now that if I use the Start Button in the car, the climate control temperature does not move from when the car was turned off, BUT if I use the Fob key to remote start the car, the Climate Control temperature changes to 23c !
So is this set-able, or turn off-able?
D.J.
124
I hope so, but I have never read about that...
Since I use the UVO app in Canada, never been an issue since I can setamy options in there.
Hopefully someone knows the technique to set it how you want it.
vipeboy2000
396
68
Middle Tennessee
I don't have it so i can't test, however i feel like i've seen videos on the remote start that if you set the temperature to a manual temp and fan setting before shutting the car off before a remote start it'll remember that rather than leaving it in auto which changes it to the default 23c?
JSolo
322
68
Chicago
This is my first car in 30+ years of driving with remote start. I'm still not keen on the idea of starting a car with no driver present. Isn't 23C a relatively comfortable temperature?
GregS
88
I thought I would try setting the Climate Control to my desired temperature and turn the car off with the key fob, didn't work.
I have found this where KIA is telling you that you should set the temperature to HERE
"For your convenience and to improve the effectiveness of the climate control, use the AUTO button and set the temperature to 23°C (73°F)."
Continuing my research.
kia stinger badges
JSolo
322
68
Chicago
What happens if you set it to 20C or 30C then press auto and shut the car off?
MerlintheMad
Sustaining Member
16,449
5,398
West Jordan, Y00TAW
It's the same as c. 73F, which according to the manual is the setting that the AC works best at in Auto. I set the AC at 73F when it is low 60s or cooler outside: and 79F when it is warmer than that outside. When the temperature is in this mid/mild range, I often just turn the whole AC system OFF.
