Check Engine Light P2565
kmrnklsn
Hey everyone,
I’m facing an issue with my Stinger 2019 there’s a loss in boost, and the car is stuck in limp mode with a CEL code P2565. I’ve already replaced the EWGA (Electronic Wastegate Actuator) with a new one, but the problem persists.
I’ve had the car checked by several specialized mechanics and diagnostics who focus on turbos, but none of them could pinpoint the issue. So right now, I’m stuck with no boost, limp mode, and the same P2565 code.
Recently, I discovered a permanent code P0455 (EVAP System Leak Detected - Gross Leak). Could this EVAP leak be causing the limp mode, or is it unrelated?
Any insights or advice would be really appreciated. Thanks in advance!
