Carbon Rear Garnish
DrewA1
I recently installed the Carbon fiber rear garnish and was wondering how to get the license plate put up. Would I need to drill holes for the bolts or is there another method to hold the plate? Any suggestions helps!
Unfortunately I thnk you answered your own question but my guess is yup break out the drill. However you could use the 3m hook and loop that is plastic. Holds something like 10lbs per sq inch. And is ridiculous to separate if its pressed together fully. Usually sticky backed so you wouldn't have to use any other glues technically. I use the hell out of it for stuff at work and home
