Car problems
Discussion in 'Engine, Drivetrain, and Exhaust Discussion' started by Mhol, May 25, 2018.
  1. Mhol
    Mhol United States Member
    80
    46
    New Jersey
    I have a premium AWD Stinger with the driver assist package. Today I was in traffic and the car just turned off. The engine stopped and everything shut down. I have had the car since March and have put on 9,800 Miles. The car started back up after 3 attempts. After work I made it home fine. I have an appointment with the dealership tomorrow. Has anyone had similar issues?
    • Informative Informative x 1
  2. Kickin Kiaster
    Kickin Kiaster United States Newish Member
    13
    New Hampshire
    Well that's not good! Hopefully the dealer can pinpoint the fault. I have the same spec car - in white - but just 800 miles. So, no I have not had any issue like this.
    Unless we can call that darn auto start stop a 'fault'! I keep forgetting to turn it off, then I get home and it shuts the car down just as I'm putting it in park - only to have it fire right back up. So I can just turn it back off!!
    Please let us know how you make out. Maybe someone else can provide a little guidance here for you.
    • Like Like x 2
  3. Mhol
    80
    46
    New Jersey
    I will keep everyone posted.
    • Like Like x 1
  4. Kazz
    Kazz United States 1000 Posts Club! Texas Stinger Swarm
    1,203
    418
    88
    Illinois
    Interesting. If this were a vehicle that was a few years older I'd suspect a connection at the battery. I've had that happen with one that had replaceable terminals that were screwed in. One wasn't tight. Yes, do keep us posted!
    • Like Like x 1
  5. Mhol
    80
    46
    New Jersey
    The dealer could not find anything wrong. They said that I would have to wait to see if it happens again. No joy...unfortunately I will have to wait..
  6. Dennis
    Dennis Singapore Active Member
    117
    37
    Singapore
    Was there any symptom previously? There are many possibility but most common for sudden stall and difficulty in starting could be due to cam or crank angle sensor. Do start from there first.
  7. Dethstr
    Dethstr United States Newish Member
    6
    2
    You may also want to have the fob transmitter and receiver checked. Had that issue with a Cadillac and the car wasn't recognizing the fobs.
    • Like Like x 1
  8. Mhol
    80
    46
    New Jersey
    No symptoms prior. It was a hot day. I drove it for about 25 minutes, it sat for an hour and then I drove it for 20 minutes when the problem started.
  9. Mhol
    80
    46
    New Jersey
    I will check on that also. Thanks for the tip.
  10. Dennis
    117
    37
    Singapore
    Best is to send in to check for any fault code captured as such issues are usually sensor related and quite easy to diagnose.
    • Agree Agree x 1
  11. BAM
    BAM United States Member
    80
    48
    South Carolina
    Yes this happened to me a week ago. I was at a red light, engine was in stop mode automatically. A msg came up saying manually turn vehicle on. I pushed the start/stop button a few times before it would turn on. I called the dealership, they had not heard of this happening, so I waited a few days to see if it happened again, guessing the dealership would not find anything. Thankfully it has not happened again so far.
  12. Stinger GT SS
    Stinger GT SS Australia 2500 Posts Club!
    2,948
    1,029
    Western Sydney, NSW
    Diagnosis for fault code as advised above & Dealer should hit factory reset to reboot computer may also fix a glich in the system.
  13. SteveCo
    SteveCo Canada Stinger Enthusiast
    840
    303
    68
    Calgary, AB
    I did that a few times as well, until I realized that after it 'auto stops' when parking, you can just press the 'Stop' button - the car will automatically shift to park as part of its normal shutdown processing (seat and wheel movements, etc.), without doing a restart. :thumbup:
  14. Joseph Spiegel
    Joseph Spiegel United States Stinger Enthusiast Sustaining Member
    714
    274
    68
    Los Angeles, CA
    Please tell me the dealer ran an ODB2 report? An unusual shutdown should have generated an error.
    ETA:
    Look into this. www.automatic.com
    I’ve had one in my cars since the first one. I never had an issue, so far, that it had to report on but... some day. It would have been great if this trapped the error as it happened. It does other stuff too obviously but it may be of help. My only gripe is it’s visible on the Stinger it was well hidden on my other cars.
  15. Mhol
    80
    46
    New Jersey
    The dealer stated they ran the reports and nothing came up. He also said it has new technology in it that they are still getting to know. This has not happened to me again.
    • Like Like x 1
Draft saved Draft deleted
Share This Page
