1. PLEASE! It is VERY important that this area is not used for the discussion of technical issues with your Stinger. This section is for posting about regional-specific things like Stinger clubs, events, local vendor or dealer recommendations, KiaStinger.com member sightings, etcetera... In other words, I do NOT want people to need to scour through several different sections to find answers about their heads up display. That's why there's a section dedicated specifically to discussions like that. THANK YOU!
Canadian maintenance schedule
Discussion in 'Canada Stinger Forum' started by WhoIsHomer, Mar 25, 2018.
  1. WhoIsHomer
    WhoIsHomer Canada Newish Member
    13
    5
    We just bought a kia Sedona and I was surprised to see that it needs service every 6,000km. Seems very low. Does the stinger also require maintenance every 6,000km in Canada?
  2. Clearly Canadian
    Clearly Canadian Canada Stinger Enthusiast
    705
    228
    Edmonton Canada
    Yup
  3. SteveCo
    SteveCo Canada 1000 Posts Club!
    1,677
    566
    Calgary, AB
    Kia has recommended service schedules for both 'Normal' and 'Severe Usage'. One of the catchalls for 'Severe Usage' in Canada is driving on salted roads or in 'very cold weather'.
  4. Manchuz
    Manchuz Canada Active Member
    349
    80
    GTA
    6,000 km or 6 months, whichever comes first, is the guidelines I received. I'd just used the km as you can program that into the car and it'll remind you for your next oil change.
  5. IamTHEvilONE
    IamTHEvilONE Newish Member
    11
    4
    Canada
    Odd, my UVO and dash service from my dealer is set to 12k and I'm in southern Ontario.
  6. Nexitus
    Nexitus Canada Member
    55
    5
    Richmond, BC
    Huh?
    According to the manual here, its every 12-months or 10,000 km
    • Agree Agree x 1
    • Disagree Disagree x 1
  7. IamTHEvilONE
    11
    4
    Canada
    Agreed that's what it says. Just saying it's odd. No idea how to actually change it without contacting UVO/Kia.
  8. Nexitus
    55
    5
    Richmond, BC
    You can change it through the center display -> settings... option at the bottom. The menu is called "Service" I believe, then you can reset and adjust your maintenance schedule.
    Not sure if that syncs to the car, but I assume it should.
    • Agree Agree x 1
  9. Arnie War
    Arnie War Canada Active Member
    366
    75
    Kelowna BC Canada
    Yes that is correct in part , but it seems interesting about driving is severe conditions which what Canadian drivers drive in lol just saying:)
  10. BBB
    BBB Canada Active Member
    232
    63
    Vancouver, Canada
    Just had my second service yesterday at 15500km. Service manager said I'm fine for changing oil/service schedule anywhere between 6K km and 8K km without any issues to the car or to the warranty. He said driving 10K between oil changes isn't recommended, nor does it fit within Kia's severe conditions requirement. So I will change oil (or service) at 7500 km increments.
  11. Nexitus
    55
    5
    Richmond, BC
    Where did you end up going for your service?
  12. BBB
    232
    63
    Vancouver, Canada
    Richmond.
  13. PMB
    PMB Canada Member
    53
    Everyone should be looking at page 7-14 of the Owner's Manual, for Kia's recommendations.
    I think the following driving conditions covers just about every Canadian if not all year round, at least in the winter:
    A-Repeatedly driving short distance of less than 8 km (5 miles) in normal temperature or less than 16 km (10 miles) in freezing temperature.
    D-Driving in areas using salt or other corrosive materials or in very cold weather
    K- Frequently driving in stop-and-go conditions
    So, you should be following "Severe Usage Conditions" which state that oil and filter should be replaced every 5,000km or 6mo (whichever comes first). The above noted recommendations are Kia's and do not represent my own opinion.
    Edit to be concise and more precise.
    • Agree Agree x 2
  14. BBB
    232
    63
    Vancouver, Canada
    I’ll stick with every 8k for my service intervals. 6k is just ridiculous.
  15. MerlintheMad
    MerlintheMad United States 10000 Posts Club!
    10,070
    2,151
    West Jordan, Y00TAW
    Not to mention 5Km right? I go with every 4K miles; 6Km is just under that, and 8Km is almost a thousand miles beyond that. Either one is just fine.
  16. PMB
    PMB Canada Member
    53
    Kia Canada should really sort all this out. Manual says 5,000km, the car service interval is programmed for 6,000km, and the UVO app (phone app) is hard coded for 10,000km. Almost all oil and maintenance manuals are set for 5,000miles (8,000km) for severe usage, and 8000miles (12,800km) for normal usage. Not to mention that synthetic and some synthetic blends are sitting at 10,000miles (16,000km)!!!
    Stinger 3.3T calls for 5w-30 GF-4 or above which is almost certainly a synthetic blend, especially if you're buying low NOACK (which you should for DI engine). So in Canada, at least in the summer, Canadians might be tricked into changing their oil up to 3 times too often.
    • Like Like x 1
    • Agree Agree x 1
  17. lucif3r
    lucif3r Canada Active Member
    145
    22
    Edmonton, AB
    I just had mine changed at 11000km. This was my 2nd oil change. Will do one every 6000km from now on.
  18. PMB
    PMB Canada Member
    53
    Edit: Quoted Myself instead of edit.... oops
  19. Arnie War
    366
    75
    Kelowna BC Canada
    Once I get my next oil change , I will run it every 10 k with 100% synthetic 0 w 30 , race oil which i already have in my engine he he
  20. nhcowboy28
    nhcowboy28 United States 1000 Posts Club!
    1,792
    613
    Alpharetta, GA
    Which oil? Is it API compliant? Hate to have a 10 year powertrain warranty voided by non API oil.
Draft saved Draft deleted
Share This Page
