Can anyone look at these jb4 logs and see if everything looks good ? running e30 fuel.
mikegt2
Can anyone look at these jb4 logs and see if everything looks good ? running e30 fuel. Back on map 2 for now until make sure its safe to run.
I wouldn't run that map 6 - you're pulling more than 6 degrees of timing at one point (look at your ign_6 value).
Do you have a log of map2? If that is clean, then try running map 3. One of those two maps is likely your limit with the fuel you have now, based on that map 6 log.
Ok thanks, so what the most ignition timing i should see to still be safe ?
