kia stinger store
Build Log - Sound System Upgrade
Aarvix
557
98
North TX
Been taking bites at this build for a while now, thought I might share it in case it helps other stinger owners, and and see if anyone has any comments/suggestions/advice.
The car: 2019 KIA Stinger GT2.
This is my daily driver and I've already put 50K on her. The HK system is pretty good for an OEM system, but I spend so much time behind the wheel I really want to
a) reduce road noise, and
b) improve the stereo system.
306550
The plan:
  • Sound treatment
  • replace drivers
  • add a real subwoofer
  • fully active DSP
Phase 1: sound treatment
I started with the trunk, there's nearly zero OEM sound deadening material back there, and with my MBRP exhaust it's pretty drone-y back there.
CLD on all the flat sheetmetal, followed by 1/64" lead sheet covered by 3mil plastic sheeting and 2mm flooring underlayment (don't judge).
306557
306567
Next I attacked the wheelwell liners. I used Thermozyte (synthetic jute with a foil radiant barrier) followed by 1/16" MLV.
I also lined the inner wheelwell liners in 1/16 MLV.
306576
Now the doors. Used Dynamat xtreme on the outer skins and 1/16 MLV behind the door card. I used 1/16 as a compromise between performance and weight. This is a sporty car after all, and I'm willing to sacrifice a few DBs to continue beating up on Chargers/Camaros/Mustangs.
306577
306578
Lastly the floor.
The stinger floor is so busy I had a hard time getting good coverage and as such, there wasn't really any noticeable reduction in noise. Given the chance I would not do this again.
Pic is WIP, I apparently didn't take one of the finished product.
306579
Results:
Soundproofing is a touchy subject, and notoriously hard to measure, but I tried to get at least SOME objective evidence. Measurements taken with REW and UMIK-1.
NOTE: these recordings were taken on the same road under similar driving conditions, but they were weeks apart and other factors could surely add to error (plus 75 is a busy road and it's a ***** to get a measurement on the same strip of road with no adjacent cars).
First, the noise at idle is definitely, and noticeably, lower.
306574
At speed however, it's harder to tell.
Subjectively I feel like road noise is less fatiguing, but not necessarily lower in volume. This is probably due to the higher frequencies being substantially lower, but under 2K there's pretty much no difference.
The door treatment completely eliminated noise from adjacent vehicles, so it's definitely worth it just for that.
306575
Aarvix
557
98
North TX
OK, time for the audio mods.
I'm budget limited, but I think this will strike a good balance between SQ and wallet....for now.
The plan:
  • Front Doors: Audiofrog GS10, GS25, stock midbass
  • Rear Doors: stock (midbass, midrange, tweeter)
  • Center: Audiofrog GB40, GB10
  • Sub: Audiofrog GB10D4
  • Amp: Helix V12, Toro MR2
First up, Tweeters.
I decided to do sails because I'm too cheap to buy new A-pillars ($100ea), this turned out to be more difficult than I thought.
First I modeled up the pods in Solidworks. I have a small graveyard of PLA templates I made to get the angles and drafts right, but after about 8 "vase mode" templates I got something that fits perfect.
306580
template model, I was able to smooth out that horizontal ridge on the fwd side.
306592
Printed in PETG and wrapped in alcantara. I really suck at upholstery so there's a few seams if you look closely, but the black hides it pretty well. Maybe once I get my voron built I'll re-print in ABS and get it professionally upholstered.
306582
306583
These are a compression fit for the GS10/GB10, and have a notch in the pocket for the wires and a center hole for pushing the tweeter out.
On the back is a counterbored pocket that I JB-welded a 3/4" neo magnet into. The mating magnet is screwed into the plastic sail trim (CSK magnet). It holds very well.
306581
The stock HK system has 3 speakers in the doors, but the 2.5" midrange and tweeter run on the same channel. There is no crossover, only a small capacitor on the tweeter.
I want these frogs to be fully active, so I needed to run an additional wire into the door. This proved to be a much bigger PITA than I expected. KIA uses a bulkhead connector on the door wiring. I do not have the tools to piggyback into this connector, nor do I want to disassemble the dash to get to the inboard side of the thing, so it's onto plan B.
OFF WITH THE DOORS!
306584
I'll be using this little grommet below the main connector. I was able to fish a wire to another hole in the body (where I also added a grommet).
306586
306585
Applied shrink wrap and snuck it into the OEM door grommet, doesn't look too out of place.
306587
Here's a link to the STL for the pod in case another stinger owner wants to print it:
KIA Stinger Tweeter Pod by Aarvix
LordShadow
48
You did a great job man!
Just curious, why the multi-layered lead/plastic sheeting instead of using the thicker MLV? It's a bit lighter than what you went with and if you go with the 1/4 stuff it does a damn good job. If it was as simple as "This is what I had access to/laying around," I totaly get it. Either way, nicely done.
Bulkhead connectors are a pita to to do properly since you have to source the pins and figure out which positions are open for use, if any. Had to deal with all the things you did when I did up my last WRX. I will say though, that thing was the quietest ride after I finished with it.
Be happy and proud of the work you did and take the time to really enjoy it.
Aarvix
557
98
North TX
1/64" lead is 1# per square foot, same as 1/8" MLV. Lead is also super limp and ductile, and forms easily around complex shapes. it was an experiment more than anything, but I wish I had bought more, because it's much easier to fit and form than MLV.
The interior parts fit pretty tight, and it's tough to get everything back together with an extra 1/4" of build-up (1/8 MLV plus 1/8 CCF). The plastic/lead/underlayment is under 1/8" total.
stoopid
417
68
Las Vegas, NV
-10db noise improvement at idle is significant. Not surprised that it didn't translate to highway speeds, it takes a lot of work to isolate the noise coming from relatively thin tires. I suspect suspension/connecting bit mods to soften the vibrations being sent into the frame would be necessary.
The tweeter pod looks good upon completion, but I'd still just use the hole already in the door.
Aarvix
557
98
North TX
Yep, lots of structural noise transmission in the stinger, not much that can be done about that.
There's around 3db reduction in the 300-2K hz range, which is audible, but the car will never be "lexus quiet" (at least we're faster!).
A-pillars are probably better for a 2-seat tune (and easier to wire), but the sails are great for the driver.
turboAWD
1000 Posts Club!
1,673
472
88
West Coast
That looks amazing.
What's the easiest stuff to use for a beginner? Would consider maybe doing some in the trunk area, but don't know where to start.
Not going to take out the seats, or anything. Taking out door cards always feels like a gamble, because I've only ever done it once or twice, and it felt like I didn't quite get it back together correctly.
Aarvix
557
98
North TX
Center channel time.
The stock system uses a single 4" center channel speaker, but interestingly the dash is provisioned for a second speaker on the passenger side. I can only assume base audio system uses it instead of the LH side.
306704
This opens the possibility of installing both a midrange and tweeter in the center dash, there's only one problem: the OEM grille only has holes for the driver side.
306705
Time for some ultra-tedious drilling!
I found a bit slightly smaller than the molded holes and went to work. After drilling I deburred the back side of the holes, then hit the whole thing with a quick pass with the MAPP gas torch to smooth out the drill marks a burrs. Be very careful here, the grille WILL begin to warp, just press it against a flat surface until it cools and viola!
306706
Back to Solidworks for some more 3D printed adapters.
GB40 adapter goes on the driver side, GB10 adapter on the passenger side. No drilling/cutting required, but I did fill the gaps with a little PSA-backed CCF and dynamat (no pic).
I also uploaded these to Thingiverse:
KIA Stinger Center Channel Speaker Adapters by Aarvix
306708
306707
The tweeters come with some slick mounting gadgets. I chose to use the backing plate with the spring to secure the GB10. Unfortunately it's not a very strong spring and makes.....spring noises....I guess.
Wrapped it with a little dynamat and no more noise.
306709
Aarvix
557
98
North TX
That looks amazing.
Doors and hatch are the most bang for your buck.
It's hard to beat Dynamat Xtreme, it's .065" thick but performs better than nearly every .080" CLD (constraint layer damper).
If you want the absolute best, get Resonix.
If you're budget limited, the cheaper products like Noico do work, but just not quite as well (but hey, they're 1/3 the price for ~80% of the performance).
A lot of folks think you need 100% coverage of the Dynamat, but there's some pretty hard diminishing returns after around 50% coverage. At that point you're just throwing mass at the problem and your money is better spent getting a sound blocker like mass-loaded vinyl (or lead in my case).
There are off the shelf products out there like luxury liner pro or Cascade VB-3, but I chose to go the DIY route. Sound blockers DO need as close to 100% coverage as possible.
turboAWD
1000 Posts Club!
1,673
472
88
West Coast
Thanks. Not exactly budget limited, more time / experience limited. Also worried about an unknown shop messing things up.
I guess since I don't really drive anywhere close to the amount you do, and it's only helping "some", I may just put in on my "someday" list.
LordShadow
48
If you want some really great how-tos from some of the most talented people in the car audio community, go to DiyMobileAudio.com Car Stereo Forum and have a look through the forums and check out the various build logs. There is a wealth of knowledge there.
Most of it centers around SQ (Sound Quality) builds which is my preference. Anyhow, lots of great reading and knowledge to be had. Get in there and get your hands dirty, you will love it!
stoopid
417
68
Las Vegas, NV
306704
Nope, base audio has same speaker on left side like yours. I assumed the hole was for access, but now that I'm looking I see the two mounting holes you ended up using and there's certainly an intended purpose for the right side.
Snowwhite
177
I've been curious lately about trying to fill the cavities in the A and B pillars with some sort of closed-cell foam. haven't had time to research though.
I got as much of the floor done as I could without removing the carpet and center console, did the back seat, trunk, roof panel, and wheel wells with Noico and MLV, but I agree, there's only so much noise reduction possible on this car. the road noise is just everywhere.
