Buffing away very shallow surface marks.
Discussion in 'Kia Stinger Detailing Discussion' started by antonini311, Dec 10, 2019.
  1. antonini311
    antonini311 United States Member
    63
    11
    Southern California
    Hi,
    The other day I had a mild heart-attack when one of my surfboards fell over. It slid between the wall of the garage and the right-read side of my Stinger. I was prepared to see scratches all down the side of the back panel. Fortunately it mostly just left a streak of wax from my surfboard that I carefully cleaned off. But it did leave about a 2" square section just behind the wheel with very shallow scratches (or maybe marring is a more appropriate term). It's mostly imperceptible and only from a few angles.
    Just wondering if a full polish is needed. Or if a waxing would remove it. I'd post a photo, but the camera doesn't really pick it up.
    And don't work, my heart has recovered. My mind is still a little traumatized. haha
  2. BertBert2019GT
    BertBert2019GT United States Active Member
    395
    256
    68
    Centreville, VA
    pictures!
    is you stinger ceramic coated?
  3. nhcowboy28
    nhcowboy28 United States 1000 Posts Club!
    1,870
    626
    Alpharetta, GA
    Mcguires clear safe rubbing compound. (Don’t be afraid to lean in). Ideally with a DA orbital. Then follow up with a polish... then wax/sealant.
    • Agree Agree x 3
  4. robz32
    robz32 United States 2500 Posts Club! Texas Stinger Swarm
    3,041
    1,210
    Houston, TX
    photos will help guide you a lot better on this situation.
    • Agree Agree x 1
  5. antonini311
    63
    11
    Southern California
    I'll see if I can capture it well on the iPhone later.
  6. antonini311
    63
    11
    Southern California
    Not ceramic coated, no.
  7. westcoastGT
    westcoastGT 5000 Posts Club!
    6,071
    2,205
    Vancouver , Canada
    Cowboy nailed it !
  8. BertBert2019GT
    395
    256
    68
    Centreville, VA
    Then you’re good to go, do as cowdoy recommended - I would still post pictures first for good measure
    • Agree Agree x 1
  9. Kimberly Lazarski
    Kimberly Lazarski United States Active Member
    125
    61
    Maine
  10. MerlintheMad
    MerlintheMad United States 10000 Posts Club!
    10,462
    2,245
    West Jordan, Y00TAW
    Meguiar's hand buffing (the magenta bottle); push the terry cloth lateral to the scratches. It sounds like the damage is light enough that this will suffice. Once buffed out, lay two or three coats of Meg's cleaner wax in there to restore the full shine. (those are the products I have/use; they are by no means exclusively "the best")
    • Like Like x 1
Draft saved Draft deleted
Share This Page
