Boost log low boost
Attached are my logs. Please help. Low boost issue. Not sure the problem
2019 gts awd
K&n typhoon
Jb4
Hks plugs
Borla cat back
Ewg wires
Fuel wires
You have something really wrong going on here. I see the pedal at 100%, but the actual throttle only goes wide open (99) for a short time, then drops back down to 50 or less. This is the ECU seeing something wrong and almost like it's going into limp mode.
Double and triple check all the jb4 connections, maybe something is wired wrong, especially the EWG wires, it's easy to get them pinned into the wrong places in the jb4 connector. As a quick test, byou could remove the EWG wires and connect the wastegate directly back to the factory harness. The jb4 doesn't require them for most applications.
2019 gts awd
K&n typhoon
Jb4
Hks plugs
Borla cat back
Ewg wires
Fuel wires
checking up on what may have happened here? I'm having a similar issue with no luck as to what's going on, here's my log.
