3.3TT BMS Stinger Tial BOV Kit Teaser Video
Discussion in 'Engine, Drivetrain, and Exhaust Discussion' started by Terry@BMS, Aug 9, 2018.
  1. Terry@BMS
    Terry@BMS United States Stinger Enthusiast Authorized Vendor
    949
    671
    98
    • Like Like x 4
  2. RandallK
    RandallK United States Active Member
    257
    195
    St. Louis Missouri
    So bad ass.. I can’t wait!!!
  3. MekstingerGT
    MekstingerGT United States Active Member
    186
    80
    Nice! What's the benefit of using 1 or 2 bov?
    • Like Like x 1
  4. NYdito
    NYdito United States Active Member
    397
    198
    Bronx NY
    Nice!!
  5. KLR STINGER
    KLR STINGER Canada Active Member
    364
    253
    68
    No specific reason to use 1 vs 2 other than venting capacity. The stinger uses 2 probably because they already had one designed for the elantra sport and was easier/cheaper to add a second one for the needed capacity of the 3.3, than design and spec a new one. A 50MM Hi flow BOV ( tial/turbosmart/etc) should provide enough flow to vent 1000+ hp
  6. Kamauxx
    3,126
    1,237
    Does this actually (REALLY) do anything other than make noise?
    • Agree Agree x 1
  7. DaBears4Lyfe
    DaBears4Lyfe United States Stinger Enthusiast
    671
    199
    Chicagoland
    Nice Terry! If you need some additional reviews and testers when you finish the product I would gladly help out :D
  8. KLR STINGER
    364
    253
    68
    BOV's/re-circulation valves are required to eliminate damaging compressor surge on throttle closure under boost. OEM plastic recirc valves are notorious for leaking boost, failing over time and increased boost level. A Fast responding BOV with a lightweight piston design also improves boost recovery between shifts, and can also help at launch when transitioning from vacuum to boost. This particular one will help a tuned car in the areas above, but for a stock car it's not necessary
    • Informative Informative x 3
    • Like Like x 2
  9. Kamauxx
    3,126
    1,237
    Thanks for the info!
  10. MekstingerGT
    186
    80
    Is this for the adaptor flang or the whole setup?
  11. Terry@BMS
    949
    671
    98
    • Like Like x 3
    • Informative Informative x 1
  12. robz32
    robz32 United States 1000 Posts Club! Staff Member Moderator Texas Stinger Swarm
    1,647
    742
    Houston, TX
    Not sure how I missed this post. But that looks great @Terry@BMS Thanks for developing this part. Looking forward to the release.
  13. DiabloStinger
    DiabloStinger United States Stinger Enthusiast
    704
    184
    Gilbert, AZ
    Any further information on this single valve design? I know a few people that would snap this up in a heartbeat.
  14. Oryan
    Oryan United States Member
    75
    16
    Since you were down there looking at the BOVs... do you see any reason or benefit to upgrading the stock hot side IC piping?
  15. jatleson
    jatleson United States Member
    57
    These are a lot quieter than the HKS kits I've seen (a good thing). Have you considered molding the DV caps onto the flange? Would clean up the look and prevent than tubes from flopping around.
Draft saved Draft deleted
Share This Page
