BMS Meth Tank Leaking?
RandyNJ
Recently noticed every so often when I check the tank there's some meth around the lid. Not sure what is causing this and it never used to happen for the few months I've had it. 20230607_124701.webp
Check the gasket in the cap.
Note that during spells of hot/cold weather, the cap can suck in air (when it gets cold), but if left sitting and the temperature warms up, it will create pressure build up in the tank.
