Are all AC components covered by warranty??
I have a 2022 GT Line with 57566 miles. Recently I noticed my AC wasn’t blowing as cold. Then yesterday it was blowing hot air. I check the low port pressure and it read between 0-10 PSI. So I put in 10oz of refrigerant and it went up to 25-30. Obviously not high enough but y1234 refrigerant is expensive so I only put a little in to see if it held.
it was blowing colder but only like low 60s. Now today it’s in the 70s. So I’m guessing there’s a leak somewhere.
I guess good timing for it to happen since I’m just barely under the 60k warranty but what AC components are covered? Specifically want to know if the compressor is just in case the issue is bigger than a simple leak.
Is there anything else I should have them check before my warranty expires?
A leak will be covered up to 5 years / 60,000 miles under bumper to bumper. Anything electrical is still barely covered within that. Over that, only the powertrain is covered to 100K miles / 10 years.
