adaptive cruise control sensitivity, how to change?
rtv900
so I know the steering wheel has the button for adjusting the distance the car uses for cruise control.
But I'm wondering if there's a way to change the sensitivity to the speed setting?
For example, my drive is lots of back roads that are hilly, so if I use cruise and I start going down a slight decline prior to going right back up again,
the car will get on the brakes and instantly back on the gas.
The speed would only have increased a few mph, but the car will NOT let it happen. It's like it is programmed to think the world will come to an end
if you end up just a little faster than the speed setting.
Anybody know if there's a way to adjust this sensitivity to speed so the car stops using the brakes in cruise?
I get that it will always let off the gas, which is fine, but the brake useage drives me crazy on an empty road where
I see a hill right in front of me
Yes, I know there is no way to change the behavior you are describing
